OVS rear 08 skid Coupler....pics?
bought this thing a few months ago and called tarr and ned a couple times because i got no mounting bracket or hardware, they kept telling me sorry and they would send it out ASAP......never happened, moved on, whatever
anywho, does someone have a close up pic of this installed, maybe a demention length from a skid cross memeber hole
sure folks will tell me to call them again, no thx
I guess you are installing this on a 07 or 08 not a 09 or 10 because the 09 and 2010 skid will accept the control unit in its factory holes. I you are installing it on a older sled give me a call tomorrow and i will give you the measurments to install it on the older sled. Thanks Travis 801-940-7777.
Hi not hatcher
You must be new to the forum or just visiting for a week. Any way good to see ya.
ok, i finally found the instructions......they say to mount the fwd bolt hole 3" back from the lower skid cross member, i did this and it dont look right at all, i can only imagine i need the oval block pictured 09 skid in the instructions that garr said i did not need for the 08, not using a backing support will cause the bolts to move around.
anywho, i just want to see a pic of one installed on 08 rails...and make the oval brackets if i must
