P
Pure Logic Tuning
OVS has finished the Pro Rmk testing the sled runs flawless and has been put through relentless testing to make sure any issues were worked out. This Pro is running 14lbs of boost and makes great speed with not as much as a hick up. The Pro kit includes the garret ball bearing turbo, air to water intercooler that has independent cooling system with pump and cooler to install in the tunnel, Tial hybrid compressor housing with 4" high flow intake, Tial v-band stainless steel turbine housing, Tial 38 mm wastegate with adjustable boost adjuster built in, Simmons high flow air plenum, OVS plenum fastening system, Billet throttle body boots with spare injectors, colds air intake, fuel pump, oil pump, oil container, OVS e-link system for tuner pipe attachment, 02 sensor, boost gauge, fuel pressure gauge and all components needed to complete the install.
This kit has it all Tial for faster spooling and more power per pound of boost.
The air to water independent system keeps the air charge cooler for more power and consistant tuning.
If you would like more info on the Pro Rmk Kit contact us at OVS 801-940-7777 or for references on the Pro Kit and how it runs contact
CRAIG AT COOK PERFORMANCE 801-920-2501
STEVE PACKER AT TURBO DOC 801-334-9140
DUSTIN OBRIEN AT OBRIEN CUSTOMS 801-698-5230
