Cowboy2, tell us more about the 1205 and 2205 bearings please.
Why are they better? Who makes them? Are they readily available?
I get the impression that the 1205 is a direct replacement for a 6205 and it would take some bearing housing machine work to be able to use the wider 2205 bearing?
Looking at all these bearing brands on E-bay is like alphabet soup. No kidding I have seen:
KYK, NSK, SKF, NTN, WJB, ZKL, NDH, MGM and RHP.
Which ones are American made and which one are the best? I did see SKF mentioned by ninemiler above, so I have to assume they are good?
Hi FB.
* Self-aligning bearing info stolen from SKF website - Two rolls of balls and a common sphered raceway in the outer ring. The bearings are consequently self-aligning and insensitive to shaft deflections and angular misalignment of the shaft relative to the housing.
* Bearing 1205 is self-aligning, same size as 6205 and a direct replacement.
* For extra meat, bearing 2205 has same ID and OD as 6205, but wider. 18mm vs 15mm. Machine 3mm out of the aluminium bearing housing, and shorten outer spacers by 3mm. Or without machining, press them in with retaining locktite, omit the circlip and shorten inner spacer.
* 99% of manufacturers list self aligning bearings. They´re readily available but less common so more expensive. They are perfect for our application as they allow for misalignment, which is what is killing our bearings. The problem is well documented.
http://www.mt-online.com/december2002/understanding-shaft-alignment-basics
* SKF is known for quality, although they only make big sized bearings themselves. They contract out for the smaller bearings, then sell with SKF branding.
* I´ve had dealings with bearing companies who volunteered to supply with markings of my choice on the sides. SKF, NTN, KOYO, you name it! Counterfeit items are rife, especially on ebay. If you´re after some high quality bearings, the only option is to buy directly from a reputable bearing distributor. Bearing manufacturers have factories all over the world. American made vs Jap vs German makes no difference.
* But our application doesn´t even come close to overloading the jackshaft/driver bearings unless they´re subject to forces they weren´t designed for. Which is why they fail prematurely. Replacing your bearings with expensive 6205 ítems from a good manufacturer won´t improve reliability, ditto adding a grease nipple as we found out. Upgrading with a fatter bearing will help, ditto installing a side-by side configuration.
* Timbersled are selling 6000 dollar kits with bearings which cost a dollar apiece. Not a problem as they should be operating at nowhere near their axial/radial load capacity. However, the unexpected misalignment isn´t catered for on the 6205s hence the constant failures. To put things into context, my self aligning 2205s from China are 10 bucks a piece. They can´t be described as high quality, but they have an easy life so don´t need to be.
