Since the issue of BATTERIES has already come up..
This is the base Radio they are reselling is a high power variant of the BaoFeng UV-82
BaoFeng UV-82 Dual Band (VHF/UHF) Analog Portable Two-Way Radio
baofengtech.com
As is common for BaoFeng, they replace models of the UV-82 RAPIDLY.
Ride208 is claiming that their version of the UV-82 can transmit at
10 Watts.
I am uncertain as to which variant they are using, but none of the UV-82s currently offered on the BaoFend website support 10W transmission.
baofengtech.com
Discover the BaoFeng UV-82C (Commercial), dual band (VHF/UHF), two-way radio. Visit the BaoFeng site to learn, buy, and get support.
baofengtech.com
Discover the BaoFeng UV-82HP, High-Power, dual band (VHF/UHF), two-way radio. Visit the BaoFeng site to learn, buy, and get support.
baofengtech.com
This radio includes a BL-8 1800mAh Battery
BaoFend offers an upgraded battery, the BL-8L 3,600mAh.
BTECH BL-8L 3600mAh Li-ion USB-C Charging OEM Replacement Battery Pack for BaoFeng & BTECH UV-82 Series Radios, Compatible with GMRS-V2, MURS-V2, UV-82HP, UV-82C
baofengtech.com
The upgraded battery would add about 50% to the total package size of your radio.
If you plan on transmitting at the full 10Watt listed capability, I WOULD absolutely spend the $20 and get the bigger battery.
If the radio is going in your Avy Bag, the extra few ounces won't be notices.
But transmitting at 10Watts WILL burn through a batter fast!
10 Watts may not sound like a huge amount of power, but with the right antenna, I can reach Australia with 10 watts.!!!
I suspect the single most important part of this radio's mountain performance will settle in on
the ANTENNA
