Options for SBA running boards
D
DM116
I am looking for options on SBA running boards. So far I have only found Skinz air frames. I would love to run them but for certain reasons I can not run a board that I have to cut of the stock board.
So I need a board that will retain the stock tunnel but I can remove materail out of?
Anybody make anything like a better board for a SBA?
I dont understand your concern with cutting stock boards or not. It does not matter what you decide to run, you are going to have to cut your stock board. I have heard of people using the new burandt boards from polaris with a little bit of modification to retain SBA running board width. That is most likely the route i will go as those boards are about HALF the price of the airframes made for the SBA. Better looking in my opinion too. For now i took the 1 inch hole saw to my boards.(free mod??)
Yeah, all boards you will have to cut the old boards out. I have the WRP inserts that you will just cut the inside of the old boards out while keeping the outside of the stockers to keep the original shape.
The problem is that I am goig to race this sled in the summer, so I have to retai the stock running board, That is why I cant use a airframe. I can get away with running a board insert such as Better board style as the stock outer rail of the running board is retained. I hope that makes sense.
How would the Burandt board work with the SBA runing board? I might be ablke to get away this because it is a factory polaris part.
The Burandt Boards work. I will be installing once my sled arrives next week. There are a few guys that have already installed them. Search this forum and there is a bit of info including a link to a good thread on HCS with pics.
