I am looking at AEM wideband gauges and sensors for my M8 turbo project. Has anyone had any good or bad experiences?
It looks to me like Boondocker uses the AEM tru boost controller gauge as thier "Electronic boost controller", so at least the AEM would match.
I love the aem afr but not so much the aem true boost gauge at least not on an m sled.
Innovate's hate snow. Its a matter of time before they will go tits up because of water/condensation. AEM will take all the abuse and snow you can throw at them.
The only true 100% waterproof gauge is the KOSO, and I've been told that they have reliability issues (system shuts off as you're cruising along, have to stop, shut down re-boot) and their shop is thinking about getting away from them.
With regards to AEM, there seems to be that High Latency issue that I posted above.
Check out www.greenhulk.net, a watercraft website. A lot of ocean riders run the INNOVATE on their Supercharged Sea-Doos and are happy w/them. I can't think of a harsher environment to run in than saltwater.![]()
I've had the same AEM boost gauge for on 3 different sleds now.. with a couple thousand miles on it in the snow.. still going strong....
Kraven.. are they doing anything to the gauges??.. cause 3 people in our group have had them.. and all 3 failed within the first season.. maybe its the water+cold weather... who knows.. but they are junk for sleds..
A few guys on H.C.S. have the XD-16 INNOVATE on their sleds, have not read any negative posts there.
On the Sea-Doo's have not read any posts regarding sealing/mods/problems on the INNOVATE.
With regards to the AEM, no one has addressed the HIGH LATENCY issue (delay in response time) and the lack of automatic recalibration feature.
With regards to sensor wear, as far as I know ALL setups use the same BOSCH sensor so it's not the sensor itself that's at issue. If you purchase the BOSCH 0-2 sensors @ a local auto parts store they come with a 1 year warranty, buy an extra carry a spare is how I look @ that issue.
Let me add that I currently do not have a A/F set-up on my sled but I'm looking at buying one for this upcoming season as I installed the PC III last season and would like to try to get more out of it.
That being said I'm not against the AEM or pro INNOVATE, and I take you seriously when you say you've had failures within your own group. How long ago, how old/new were the INNOVATE units that failed??? Since the INNOVATE is the only true digital unit out there , were these reliability problems early electronic gremlins that have since been addressed??
When I spoke to BIKEMAN about the INNOVATE they said they USED TO have reliability issues with them, and now they sell the KOSO. Then when I asked SLP about the KOSO (the only A/F they offer) they're considering dropping the KOSO due to reliability issues.
So, should I buy the AEM with NO recalibration feature to compensate for 0-2 sensor wear and what about the SLOW response time with the AEM, effectively providing correct data but in the wrong column of the fuel map???????
Or do I buy the XD-16 and keep returning it for warranty repair/replacement and be without an A/F set-up for half the riding season???????![]()
I have found that if your sensor starts ready low, to clean it out with a propane torch and that usally gives the sensor longer life.
Justin Silbernagel
