ok i pulled a bit of a boner today while cleaning the carbs (mikuni tm40's) on an '03 800 HO with rage cages on it...i didn't check the settings on the fuel screws before i popped them out..on the older mikuni carbs (vm's etc) with the separate air & fuel screws i could dial it in from the 1 1/2 turn base setting etc...does anyone know the base setting or the absolute minimum ("safest" lean setting) for the fuel screws on these carbs?i'd hate to have to yank my guts out or melt some chit before getting it dialed in...i assume that the idle speed adjustment controls the air setting for these carbs- so i shouldn't have to worry about that (cause i left it alone) any suggestions would be great cause once the carbs are on the machine it's next to impossible to fug with the mag side screw for adjustment...
