One Ton Advice
Good buddy of mine just scored a great deal on 05 RT1000x:eek: $3,600.00 Miles, great shape...only mods we are aware of is a can which oddly has four small burn holes penetrating metal in a perfect circle,minor clutching work,simmon skis and evidently the secondary radiator has been bypassed?? He wants to dump about $2,000 into this beast...Question: Is there a good pipe can compo that works well for this machine or are is he better off just replacing the can. Also wants to put it on a diet.. maybe a seat and perhaps some shocks. Where do you guys think he would be best served within his budget (other than not investing at all) . I also recommended he have the top end rebuilt...As the 3000 miles are all original and the rings have never been replaced. Thanks in advance!
DJ clutch kit; get rid of all the xtra plastic crap around clutches, remove all under hood foam, swaybar, cheezy rear light rack, rear cooler, front outer idlers I forgot what else right now.
15 wide chain & top gear with 440 spacer & 19T or 20T top gear.
Boss seat (on my wish list)
07 mid alt prog
I run HPS can (like it) some say just ceramic coat the stock pipe & Y
'08 800xp in line T-stat.
Some type of filter system on throttle bodies A MUST!!!
without a T stat and filters I would be somewhat nervous about the crank bearings but who knows, 3000mi top end is cheap would doo it anyway.
Boony box and EGTs
I'm gonna build and try a home made version of the T%*#sled intake, it will drop some weight I'll see if it makes or looses power to determin if it stays.
