R
RKT
Circa 1989 MT Stadium racer
ONE OF A KIND!! NONE OTHER LIKE IT IN THE WORLD!
This was a competition rally car racer!
Was a 60HP (500cc) 2 stroke engine (pre-mix)with very little power!
NOW is a 738cc Ski Doo Snowmobile Engine rated 155 HP oil injected engine with PLENTY of power.
VERY FAST!
Electric Start
Added a much larger cooling system (Radiator from a VW Rabbit) with electric Fan
Added real snowmobile clutches (TRA III Primary and Arctic Cat Bear-Cat Secondary)
Added full oil injection system. Yes it runs on pump gas and you fill up at the pump!
Has Regulation 10 gallon non-slosh Race Fuel Tank
Added a tuned exhaust vs. the non-tuned pipe that it came with.
Added a solid jack-shaft vs. the 2 piece (very Wobbly, out of true) jackshaft
LONG travel FOX shocks with limiter strap all the way around!
Changed the RPM tranny to have a higher gear ratio and stronger support. Perfect for the Dirt or Dunes!
Made the engine mount plate so that it would allow for a rubber mounted engine (less vibration) and NON-Twisting action when floored (engine and clutches stay completely aligned at all times)
Has FULL Lights with Brake lights as well! This thing could be street legal!
Raised the seat height to be able to see over the long hood
AND MUCH MORE!!
This thing runs fantastic!! It is great on the dirt and equally fun in the sand!.. It is an absolute Blast!!
$8900..
VERY FAST!
Electric Start
AND MUCH MORE!!
$8900..
