One of a kind custom built M1100 4 stroke
T
tar
The only one I have seen.
Built in 2011 and 2012. Has a 2010 Z1 1100 engine transplanted into a M chassis.
Just put on the D&D turbo up grade,new boondocker box.
ECU reflashed by D&D to raise the rev limiter and change the timing.
Have not put much time on this new set up. Was told 400HP potential with race gas and maybe bigger injectors. Injectors can be sent out,no big deal.
Still tuning and clutching.
Head studs.
Surge tank.
Two fuel pumps.
Z bros front end.
Ice age rails.
Camo 2.5 track.
Pro logger
New M rear tunnel and big cooler
If you like the M chassis and the diamond drive this is your sled.
To much sled for me.
So many hrs and dollars into this project,been fun as I enjoy building sleds.
Sled is easy to work on just open the hood. Changing plugs is simple and only takes a few minutes.
15,000.00
Have many extra cat parts,half barrel race gas.
Will take offers, maybe trade for muscle car or ?
Sled is licensed.
Tar.
uploadfromtaptalk1389646185442.jpg uploadfromtaptalk1389646543949.jpg uploadfromtaptalk1389646568212.jpg uploadfromtaptalk1389646593487.jpg uploadfromtaptalk1389646620493.jpg
This sled will run well on pump gas, I was running race gas to be safe. It will run a lot of boost, so it requires good gas. I was going to run about 25lbs with av gas.
This sled doesn't have the drive, the reverse, the heat and belt problems like the new sleds, plus it's lighter.
Thanks for looking,
Tar.
Forsale or may part out if I can sell the engine.
1100 will make a rzr fly! If anyone needs an engine.
Tar
10,000 takes it
This sled has a bunch of D&D parts.
Special ecu programing.
This motor will produce tremendous boost and HP. This sled rides very good and is very fast.
You can call D&D for info. Need to sell. I'm too old for this thing. LOL
Tar
Back to the top. 7500.00 takes it and all extra parts half barrel race gas.
Thanks for looking
