One for the M7 Guru's
I have an 05 M7 with 8200 miles on it with a major rebuild on it down to the crank at 5800 miles. When I grab a hold of the PTO shaft and pull in and out on it, there is a very little movement in it. Not side to side or up or down, just in and out. Is this a bad thing? Does anyone know what this may be or could it possibly lead to a problem?
Thanks for any help.
i cant answer your question, but the term your looking for is thrust.
like in some automotive/diesel applications there are items called thrust bearings that minimize the lateral movement of the crankshaft. if it seems excessive, then i would be worried.
Thrust!
Is there such a thing as a thrust bearing on sleds? The pto has very little movement on the shaft. Sled runs perfect. Was hoping someone had a little more detail input on this. Thanks for your response.:rolleyes:
Just to make sure, did you check the bolt on the primary to make sure it was tight, does it have the washer on it?
