? On Exhaust Valves
Pro-8250
Sorry if this has been brought up before.
2011 Pro RMK 1500 miles. Pulled the exhaust valve on the mag side. It was about as clean as could be. Would the other valve be as clean? I would assume so. No use pulling it out if it isn't needed, correct?
Also the gasket was 100% intact. Should I replace that gasket? Broke that cheap hose clamp they put on the hose, back to NAPA.
I will say I have been looking over both of the 2011 Pro's we own very thoroughly for some time now , and so far I have not come across any problems other than some oil leaking out of the Y-pipe exhaust pipe connection on both sleds. Permatex Ultra Copper fixed that. No broken primary spring, no blown belt, piston, etc. Is it just a matter of time? :clock:
FYI: It's 38 degrees here in northern MN. 4" of snow on the ground. This winter sucks!!!!
This winter sucks? Winter, what winter? Has it already came? Did I miss much?
Sucks is about as understated as you can get without cussing.
That's your call, I like pulling both but I'm ocd about that stuff. Odds are it will be clean also. Guess if your not having runnability issues I wouldn't worry about it. I always reuse my gaskets unless one cracks pulling them apart, never had a problem with them leaking after. X3 on the lack there of the season called winter, we finally got enough snow to go for a decent ride here a couple weeks ago, just in time for it to rain and shrink it all back down to near nothing.
