On brakes
I would just make sure that the fluid level is right, you have the correct dot brake fluid, and that there are no air bubbles in the line as well as the bleeder bolt being tight. If all those check out good, then I'm not sure. I had the same thing with my shift lever and once I got home I realized the the fluid level was right around zero. Easy fix. Good luck
