Old TSS shock on 2018 ARO
Hi guys! Moving from a 2013 KX450 on a 2015 MH LT to a 2016 KTM 300XC and a n 2018 ARO 120 this year. Wondering if I am able to use the TSS shock from my 2015 Mountain Horse LT on my new 2018 ARO 120 set up... Has anyone done this? Wondering if I can use the trunion from the solid strut on my shock or if that will work.
Thanks in advance!
M
Sep 18, 2015
44
16
8
Easiest way to check is through Timbersled's website. Plug in what your old set up and new set up are and compare part numbers. I would figure you could, but don't take that to heart.
C
Apr 22, 2019
191
136
I do not believe that TS has changed the TSS shock since it was introduced.
But yes...you should probably check part numbers on Polaris's microfiche.
byeatts
3,404
1,215
the TSS shock was changed internally 2 year ago with new model ,different compression and rebound ,same body.
