P
prairiepowderhead
I will try not to drag this out, my 08 apex has a stutter in the top end. It has a boo docker type of turbo setup , side mount, 3072 Garrett. It has rods and pistons head studs eagle cams, valve springs and pretty much everything else you can do. 8.5 to 1 pistons. When I first run it when it's cold it rips, then after it gets hot it acts like it drops a cylinder, the boost still comes up but it will only rev 9000 , doesn't matter if I run 12 lbs or 25 lbs, also doesn't matter if i change fuel up or down. One thing I thought of is that I haven't changed spark plugs for probably 3000 miles or more. It also has a knock box but I've ran it unplugged and makes no difference.
It really stutters on the top end at full throttle otherwise sounds fine. Any thoughts please.
