Ok here goes 901/925
Hardass
515
Troy Montana
2009 m8 turbo can i just bore the cylinders out and not do any work to the ports? just use what ever it was for the 800? I know i need to open up the heads and do the valves.Just curious
rusty rider
490
114
Middle of the West
Raise transfer ports, cut valves to bore, comp ratio. Cut stinger off pipe, 2" I.D. pipe, stock normally is a bit smaller, insert new stinger size just enough inside end of pipe to weld.
Hardass
515
Troy Montana
i already run the 2 inch stinger and i was sent the porting specs so i may do a set my self. As i have extra stuff any way. thanks
