I went for a 30 mile ride today and when i got back to the truck my oil was all the way down to the return line. Are you guys using this much or am i running rich?
If your talking about the hose that connects to the bottle about 1/2 way down, and is routed down between the cylinders to a brass fitting on the front of the engine just above the oil pump..... it's not a return line. This is how the cross shaft is lubricated.I went for a 30 mile ride today and when i got back to the truck my oil was all the way down to the return line. Are you guys using this much or am i running rich?
Are we talking about an 05 or 06 tank?
My 06 on an aggressive 40 mile ride will be at the water pump cavity hose/oil line outlet of the tank. I run my oil pump turned up a little.
My oil is filled BEFORE every ride.
