oil pumps
tree climber
who has found something that REALLY works. mine has about one tank of fuel through it and the oil pump seems to be crap already. it went from about 7lbs of pressure to 2 or 3 at best.
the one that BD uses works great.. kinda spendy, but considering i have over 6k miles on mine and its still pumping like it did the day i got it. i'd say its worth the money
Are you talkng about the injection pump or the oil circ pump for the turbo?
What turbo kit?
If we are talking about the turbo oil circ pump here....Do you have an inline fiter on the suction side of the pump?
Where is the pump mounted in relation to the tank?
i have a silber kit. the pump is between the tank and turbo i guess you would call it haha. i pulled the filter to make sure it wasnt plugged made no difference. it doesnt sound like its running smoothly like it did when i primed it when it was brand new. like kinda a clunk noise
We are having pumps built this summer, same pump as BD is using. Its the Gotec pump, we are having the driver boards built and they will be molded to the back of the pump and either vaccum molded with mounting tabs or epoxied into a potting box like BD does.
The pumps will be offered to anyone that has a Silber turbo kit without this pump for cost.
Retail price will be around 150 for anyone looking.
Thanks
Justin Silbernagel
Thanks
Justin Silbernagel
Not the same, we build ours. Thx D
You build the gotec piston pump you have been using?
I know you probally build the driver board you solder to the back of it.
I wish I had the equipment to build a pump.
Thanks
Justin
BD pump is actually the best you can buy for money.
I like that pump.
But!!
on my D7 BD the pump died after 25-30hours.
i think the should fix it on the oil tank.
Now i use a piston-based oil pump for 150USD and it works last 100-120hrs perfect. but i wll switch back to BD this summer.
i will try justins new pump. i think pretty much anything would be an improvment over the original ha
tree climber, get ahold of outlaw addict on here and ask him about your sled pump, his buddy rob is going to do my turbo this fall. Rob will be able to help you out and he may have an extra pump laying around. he lives in sioux falls, dell rapids area also. hope this helps
