Oil pump question
sledhappy
I just went through my motor for maintenance sake. I'm re installing and forgot on the oil connecting rod from the throttle bodies to the oil pump. Does the arm on the pump go on the right side if looking from the seat? This winds the spring about 1/4 turn. I believe this is right and I don't want an issue.
Thanks for your help.
Yep, goes on the right and turn it counter clockwise to load the spring. If there is no spring tension, it's wrong
