Oil pump position
anderson
Ok I put on my fbf cable and now the epa is following me. Useing a quart of oil per tank of gas plus. Using over twice what it did before the swap. Directions say have marks parralel if i remember right or are the suposed to touch = or -- does anyone have a picture. is curantly at =.
Mine has always used a quart of oil per tank since it was new. I have had it to the dealer twice and they said it was set right. How much should they use?
Mine has always used a lot as well, and runs good doing it.... just make sure to align the marks and you're fine...
oil pump
Well it must be close then. Just seems like its using more than before. Thanks for all the help.
directly below the throttle bodies. You can just see it with a flash light. I think the best way to adjust with the motor in the sled is to remove primary clutch and adjust the cable right by the throttle cable. Alternatively, you could do trial and error by removing the throttle body, adjusting and putting it back to see the results. You have to do the trial and error because when you removed the throttle body, it pulls the cable so you can't get an accurate reading.
Replace the cable with and FBF cable if you can. The factory oil cables are unreliable and stick all the time and are a complete pain to adjust.
