oil pump linkage fell off!!??
Just bought my first RMK, been on Doo's till now. 2012 600Rmk carryover. Since there is no snow I was going over everything and noticed the oil pump was not moving with the throttle. It appears that the linkage on the throttle body end was never hooked up or fell off? Anybody else having problems with the plastic clips or is this a oops from the guy that installed motor in chassis? Luckily I saw it before I burned up the premix!
IIRC, the oil pump will go to full output when not connected. The linkage ball should snap back on.
I just put my turbo on and ran into this problem. MAKE SURE you rotate the lever all the way around towards the clutch side when making the connection to the tb rod. IT will NOT work if you dont do this. it will make more sense
when you get in there.
Looks like adjustment marks are lined up. Not too sure. Luckily a buddy bought one identical to mine and its sitting in my garage. I will be comparing them tomorrow. First time I can ever remember being glad there is no snow!
