Ok guys, so I need some help here. So coming off of the throttle bodies you have that arm that goes down to I believe the oil pump and attaches to a part which is on a spring (Look at attached picture), anyways, I lost my setup on that and the spring came off causing the thing to spin, so now the spring is not attched anymore (I could attach it again) and I have no idea what position it needs to be in because it span freely.... SO, whats actually inside there is it a bearing and this wont effect setup at all? Can I just hook it back up and its good to go again or is there a specific position it needs to be turned at?
Any info helps (and no I dont have a owners manual)
Thanks guys
Thanks guys
