Oil pump blead screw ????
Put a new oil tank on my wifes 08 M-8 and since I had the oil line off I need to blead the pump. Can somone point out the blead screw.
well
I actually don't see it on the fische there. It is kind of a pain to get to. I took the bottom of the belly pan off. You have to run the motor too, as I recall. It is just a 'bolt', I believe it is a 10mm. If your laying under the nose of the sled looking up it is on the right side. Like I said it is a pain to get at and it makes a mess. As far as the fische goes it would be on the left side (the side you can't see) and below 16.
Hope it helps.
Start it on a stand, let engine IDLE, pull on the oil cable so oil pump is wide open, watch oil line for bubbles
