oil pump adjustment???
cubby
I have a 02 700 summit and I had a aftermarket throttle extension on it and now I'm wanting to but the oem one back on. Well the marks that the manuel show to be on my pump are not on the pump so I'm wondering how am I to adjust it right? And also look at my pictures and you can see that the cable going to the pump only has 1 nut on it, so how does that tighten up? Not like the other nut can just fall off because of the plastic insert on the end that does't come off. Any help would be great Thanks
Tighten the nut that is there. the adjuster nut is located back up along the cable before it goes into the splitter under a rubber sleave. roll the rubber back to access the adjuster nuts.
The alignment mark is the small pin right by the marks on the arm.
