J
jTrue
I see 3 marks on the throttle lever, two larger marks on the ends and a small mark in the middle, is that correct? When I pulled off the carbs the lever would open past the top scribe mark on the lever. I tried to adjust it to line up exactly when at WOT. I'm a little confused about the adjustment process. It seems like in order to get the top index mark to line up with the mark on the pump body when at WOT there needs to be slack in the oil pump cable, is this correct? Just off idle the oil pump cable is taut but not pulling up on the oil pump lever. Any help would be appreciated. The picture below is how it is currently adjusted. At WOT the top scribe mark on the lever lines up with the scribe mark on the pump body.
![IMG_0162.jpg](http://img.photobucket.com/albums/v514/JTrue/IMG_0162.jpg?t=1266708858)
