Oil injection pump for Turbo
B
Boyko
I was wondering what has to be done to set up the injection pump to grease the turbo on a 09 M-1000, I never had one of these motor apart, How does the center gear in the motor get lubed?
This is how a twisted tubo works. they use the Mech. pump to oil the turbo, and you drill and tap the case and run an oil line to lube the center section
Take the two lines off the throttle body flanges and run them to the turbo inlet. Cap the barbs off. Run your suction line for your turbo oil tank to the oil pump. Mix your fuel 32-1 and run it. You can only do this with a ball bearing turbo though. You will need to fill the oil tank through the winter due to oil loss from the third port on the pump going to the cases. I have ran mine this way all winter. I use 2 stroke oil in the tank. I love the room it gives you in the engine bay without the oil injection tank.
