Oil Injection Delete
Bought a half finished project (800 HO) - I believe the rez to replace the oil injection is hooked up wrong. Does anyone have pics of where it should be connected etc? Should it be drilled into the cover plate where the pump used to be? I searched Snowest and DooTalk but if someone has a link that I couldn't find - that would work too. Thanks.
if your using the 440 res. it hooks to the nipple on the case directly above the blockoff plate. If you don't use the rese. the plate needs a 1/8 npt fitting. connect a hose from it to the nipple above.
