Oil every where y?
D
DA_WILKS
New member
Oil every where y? HELP HELP!
i just pulled my sled into the garage to look it over and put on a new belt and when i took my belt cover off the bottom side was coated with oil! but thats not all! the clutch and suport behind it was coated and under the y pipe and down are coated with oil! WTF is going on with my sled to make it do this? need to no ASAP got big trip coming up and not going without my 900!! 900 for life!!
Coupla options:
Exhaust leaking burnt oil or primary has rubbed through the oil feed line from the tank. The black could be just belt dust.
i now its not belt dust cuz its liquid and i can wipe it off! im going out to look at that line and should i be worried bout any thing big happening? like my motors going to go maybe er i need a new crank?
I found the problem! the bottom bolt for the y pipe on the clutch side is missing! That would do it! thnx guys for your help now i have some cleaning to do! lol :beer;:D
If it's unburned oil you have to look at the line or the crank seal. If burned it either has to be the exhaust mniifold or possibly the EV bellows (but this would likely be on the hood as well)
Oops, too late. glad you found it..:)
Now all you need is an 8mm bolt.. get out a magnet and start fishing!
i found it under the carbs! I just took off the y pipe and im going to replace the gaskets will im in this far!
Yup, that'll do it!:eek::beer;
i got new gaskets and i went for a ride and it has a new coating of oil! is it a crank seal?
Now comes the point when........
Pics of exactly where you are seeing the oil would be immensely helpful
here you go :) the support behind the clutch (in the first pick) was pitch black the first time i noticed it be it is still kinda coated? Y!
IMG_0155.jpg IMG_0156.jpg IMG_0157.jpg IMG_0158.jpg IMG_0159.jpg IMG_0160.jpg
Looks like somebody needs to do a better job keeping their sled clean, that way, when it starts leaking it is easier to find the source.
check the inlet line to to oil pump from the oil bottle. pull the protective cover off and inspect the whole hose. my brothers had a small pin hole worn in it under the black plastic protective wrap. it was doing something similar.
also check to see where the vent from your exhaust valve solenoid is routed. it has black oil coming out of it too.
