B
b_sandgren
I have a OFT Jacobson Roll-over valve kit for a 2008 and up nitro. Brand new, never installed.
Here is the describtion from OFT website. They are $200 from OFT, I will sell this one for $150.00. Thanks PM or text me at 530-300-2420 and I can send pictures.
The patented Jacobson roll-over oil valve kit is designed to prevent engine oil loss during a roll over event of Yamaha 4 stroke snowmobiles, and has now been integrated into OFT Racing’s "Moto-R Kill" tether system.
The OFT Racing "Moto-r Kill w/ Jacobson Roll-over valve" (patented) will take care of this problem, while also providing you with a top of the line engine kill tether system. In addition, our kit plugs directly into the factory wiring harness with no slicing and dicing of your OEM wiring harness!
We have designed this kit using OEM Yamaha weatherproof connections and a completely sealed Bosch style relay and connec of idiot proof! Unplug the OEM harness, plug in the OFT Moto-R Kill harness, and install the Jake valve in-line on the oil tank vent. If for some reason you need to remove or bypass the tether kit, changing the sled back to stock form is as easy as unplugging one or two connectors and plugging them back in to the OEM harness. The Jake valve will remain in a "flow through" open position.
Designed to compete with, and surpass more expensive competitors products, The Moto-r Kill w/ Jake Valve kit features the race-ready and off-road proven tee handled Pro Armor kill switch assembly. The Pro Armor switch provides extremely easy "gloves on" operation, and bullet proof, all weather performance. With Pro Armor’s positive clip latching, you never need to worry about the tether not seating or trying to thread a needle sized clip through a pinhole with your thick gloves on as with our competitors.
The tether switch will mount on either 7/8", or 1-1/8" handle bars, and the kit includes a "test plug" that will allow you to disable the red OEM handlebar mounted kill switch.
Fits: 2008 to current FX Nytro
