B
help!! 07 rev stall
I guess im not the only one with this problem... but i need a fix!!! flat areas boondocking is fine but once you hit the hill more than once and you load the engine a few times it goes into a stall mode. it hits around 7600-8000 rpms than it drops down to about 6000 and stays there. sometimes it clears up but mostly you have to turn your sled around before it gets stuck and head back down. iv changed out springs,weights ,secondary,helixs, rebuilt clutches, rebuilt valves. checked vac hoses...what could it be?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
