O7 M1000 check engine code. 7 flashes at WOT
My O7 m1000 check engine flashes (i believe 7 times). Only at wide open throttle. Hard to count em when going so fast. I deleted the power valves couple years ago. it has a can. everything else is mostly stock. It runs fine, haven't changed anything this year. thanks
7 flashes...
7 flashes on an 07 is for "low power DC output deactivated" (Gauge/Taillight/APV valves) make sure your PV bypass module is still plugged in to the harness
