K Klutch Member Premium Member Jan 5, 2009 #1 What pressure should I start with for all four shocks and I'm running a sway bar for now. Thanks.
F funjunkie Member Jan 5, 2009 #2 I run 65lbs in front shocks. In the rear suspension I run 120-125 in the rear and 75 in the front. I'm 200lbs
B Butta Well-known member Lifetime Membership Jan 5, 2009 #3 On the rear skid I run 95 in the front shock and 145 in the rear....I'm 230 on a good day.
SAWYER Well-known member Lifetime Membership Jan 5, 2009 #4 I'm pretty much what funjunkie runs. Seems to work good. I'm 165lbs
K Klutch Member Premium Member Jan 6, 2009 #5 Butta or Sawyer, what do you run in the front and do you run a sway bar, thanks.
B Butta Well-known member Lifetime Membership Jan 6, 2009 #6 I have the stock pogo sticks up front.....
WingNutRacing Well-known member Lifetime Membership Jan 6, 2009 #7 Butta What have you done different with the stockers, I'm gonna have to keep them for a while myself. So far I've just tightened the spring up a little, but they seem to need more.
