Just wondering where the most engine vacuum is created on a Nytro. I got vacuum from the left side nipple on the throttle body...is there a better place that creates more vacuum?
I can't see why it would make any difference. I think if anything it might be worse because you would be injecting air from the compressor housing in to the throttle bodies for a split second after the wastegate opened. Unless of course you had the blow off valve in the charge tube, or one in the charge tube and one on the intercooler. The MCX turbo's have BOV's on the turbo, so it would probably be ok with a 16t or 19t. Confused yet? How about just not do it. lol. Or maybe it would be better because you would be injecting air directly from the turbo in to the throttle bodies rather than having all of the charge go through the intercooler! Ok now I'm confused. Try it and let us know how it goes.hahahaI talked to a guy who builds a lot of turbo cars and he claimed that hooking vacuum to the compressor housing will make that turbo perform at its optimum capability...this may be true, but may not be the case on a sled?? I don't wouldn't think it would hurt to try...?
