I have a fix for the oil drain problem. Its an electric shut-off solinoid valve system that is controlled by a special dual curcuit tether switch. Pull the tether (leave the key on) and it shuts off the motor and closes the valve at the same time automaticlly. Plug the tether back in, the valve opens, fire er up and away you go.
The valve is mounted "inline" in the OEM breather hose. So on stock sleds it still vents into the air box.
Comes in handy when I'm stuck, sometimes its a lot easier to roll the sled on its side and drag her around. With a roll-over valve, I can do that, just like I would if it was a 2 stroker! I also use it when I want to tip the sled on its side to work on it.
Because of the parts required to build a kit, it does cost me more to build a system. More so then some of the other guys set-ups. However there are no bottles to drain or filters to clean. Just install it and ride!
Eventually I hope to start making kits to sell. I'm pretty much in the testing stage right now. I do have I few out there on the snow now, both stock and boosted, with good results!
