Nytro Mtn. Tamer wearing on rear shock??
Q
quadtrac
New member
I looked over my Nytro Mtn. Tamer suspension when I had it out of the sled and found that the rear shock had some wearing on the very top of it. Im guessing that its getting worn from the track rubbing over it. Right now it looks to be worn about half way through. Is this something that has to get fixed? Thanks
you need to use bigger wheels on the rear suspension mounting shaft. run the larger ones that were on the stock skid
also check your limiter straps up front, ice builds up around the lower shaft they're bolted to and then they snap, sending your suspension for a sh!t. my buddy just had 1500$ worth of damage due to just that
