Have enyone tried??? Can't find and info here or at HCS...
Biggest different is the chassis, not the motor. The Nytro motor is a very good motor, chassis totally sucks.
It's not a problem, head over here i'll race you
Using Tapatalk on Android ICS pad.
I have a cabin in Kilpisjarvi Finland.... Plenty off Nytros with MCX 270, just need more snow
Agree, i would not hesitate one second to race against an 1100 EVO, and we have plenty of snow.
All for fun of course.
How is it possible it hasn't been done yet?
Wonder how much boost an 1100 needs to reach ~275-300hp with an SC.
And is it done on pumpfuel 93 ?
260 on 93
300 on 100
None of the Evo kits run head shims. What boost each kit needs to make the kits rated power is dependent on the elevation, just like stock.
We always talk boost pressure @ sealevel because it rise @ altitude.
Do you know how much boost is needed to reach 260hp?
I'm surprised/impressed no chim is needed to reach these powerlevels, whats the trick to avoid detonation? (Low compression from factory, plenty of fuel, timing retarding?)
I only know boost numbers from dyno sheets and actual mountain riding. I could hazard a guess that 260 would be under 20lbs at sea level. For more exact numbers just contact Jim at Evo.
. Cory what kind of fuel do you run in you 270 mcx nitro.also what kind of money to build one of these cats to run in the 270ish HP.I haven't had a chance to get them side-by-side yet with an MCX-270 Nytro to compare but these new EVO Cats rip. We have done a BC250 and a BC275 now. It's tough to tell because the Cats are decievingly fast. A MCX Nytro hits super hard once you get into boost and feels crazy fast and pulls hard, the EVO Cat doesn't quite feel that way as it is a much smoother more controllable power and doesn't have the lag and boost hit a MCX kit does I find, but when you let off a EVO Cat you realize you are really hauling ***. I think things are going to get really fun this winter and gonna be alot of EVO vs MCX stuff going on. Can't wait for Yamafest! Should be fun!
Our BC275 was making 26lbs boost on C-12. It's meant to run 100LL.
Happy sledding! - Cody
