Nytro low end hesitation
1madbird
Polaris Klim 509
got a turbo nytro and I am running a Pure logic control box and cant get the low end hesitation to go away. It is not there if i mash it from a dead start but when your low on boost crusing and mash it, it hesitates any one else have similar issues or ideas.
what are your numbers on the box at what are the co's as well you maybe to high on the cruise mode. post your settings.
Nytro hesitation
With Nytro in all setups so far from stock to boosted we can make it go away and even more throttle response because we have full control over timing and fuel.
Dobeck box is not even close to a mapping setup.
As for how much boost is the same as Dobeck which can push injectors to 100%
We can make more power by pulling timing with boost.
www.powderlites.com
Power Commander has the Fuel and timing control like the RB3 as well. You can definately get better response by using either.
I am running at around 13-13.7 on my A/Fs and the box I have tryed the green low and high and the yellow low and high and the red low and high. I have found it best at 2 lights on the green and about 4or 5 on the yellow and the red around 4 or 5 and the boost 2 from the max. And my COs are at the stock which is 0 I think but I have heard to many people not agreeing on how this setting works.
Have heard that the RB3 isnt as fast when it starts to pull timing and it is really a pain to tune on the hill when you gotta carry a laptop. I want to tune on the fly or better yet never have to touch it. I like the power commander but the cost and haveing to buy the additional stuff to make it all work doesnt appeal.
So no one has really been able to answer my question can I make the pure logic work or do I need to change to a RB3 or Power commander
The pure logic will work fine I have no problems and the other nytro,s I have seen have no problems either. its all in the fuel pressure and or settings it could be in your clutching as well.
Well I dont know what kit its on but I run a PL on my alpine and it has no stumble. To be honest most of the guys with this prob that I have seen are running a rb3. I have my co's at -20 the only thing mine does is after a slow run in the trees i need to clean it out with full throttle for 3 sec. I love the full adjustability up the mountain, and ability to run any boost level up to 25lbs
try playing with youre blue / yellow mode i found a stumble that is tuned out in that mode .
Thanks Guys for the input I will drop my CO and try that
