Nytro Insulation Removal...****Glue!
Want to remove the insulation under the hood...how do I get that glue off along with the bits of insulation left, cleanly and no damage or discoloration to the panels?
yes yammi has the meanest glue on the planet brake cleaner i found the best but it takes allot of work.
I've had mine upside down enough to leak oil out of the breather, funny thing is that where the oil has soaked into the foam on the panels, the foam isn't sticking anymore. I plan on letting it soak this summer with some oil and see if I can get the rest of it off easily.
Acytone(sp). Pour it on the foam, let it absorb for 8 to 10 mins and it will fall right off.
Took the Pepsi challenge on this one and tried about everything, unfortunately I got to the Coleman fuel last.
Thanks Hillclimer, Coleman fuel is by far the best. I've fought insulation on every sled I've owned for years...no problem now, thanks to you and Coleman fuel its no longer a project I dread.
BL
