Nytro icing up??
Is anyone else having problems with there Nytro loading up with ice???? Under the tunnel and icing up under the steering rods and destroying the rubber boots??? Has anyone modified the skid plate to prevent this?? Any help would be good thanks.
Had the same problem with mine last year too. Never found a fix for the boots.....its a poor design the way they are held on there IMO. I got a lot of snow in the nose as there are a lot of little holes and spaces between some of the body panels........dealer used a silicon type gel and sealed everything up there. It worked pretty good, cheap fix. I would imgaine you could do that with the boots too.
