Nytro HP at a given boost level?
samsquatch47
Hey guys I'm running an impulse race gas set up with the 2871 on my Nytro with Boost-It fuel system.
Like most I have a boost knob and can adjust my boost psi. People always ask me what HP I'm running? I run it at 21psi every day on straight AV gas. Anybody ever dyno their Nytro at that approximate boost level?
I know it's hauling some a$$ but I'm just looking to get an est HP number to throw out when asked and not look stupid.
How about 25 psi? I could crank it up with C16 but 21 seems plenty ;)
Cheers!
Cheers!
Estemated 330 , avgas is better than c16 egen it comes to engine knock
Sweet thanks hotmail! Explains why it pulls hard! :)
What boost have you ran up to with Av safety?
I have Carrillo Rods and head studs as well in my motor.
Have you ran it against some other turbo's?
330hp could be close @ sealevel, a tad high in my opinion, but what matters more are the tune of the sled "how well is it running vs others"?
Using Tapatalk on Android ICS pad.
Good point. I've compared it to a lot of 270 mcx nytros and it pulls harder then those. Plus way less lag with the front mount. I ride with modded mcx apex with a ported head running 21 and his pulls a little better.
Basically looking for an estimate for cabin talk while in the hills.
Lol, i see, in that case i would say your sled are running good.
And you can say "it's got enough" :).
An actual HP # are hard to say within 10hp, cause i don't know the effeciancy of Impulse IC and header, but with an 2871 and a good tune, and the fact it runs harder then MCX270 i guess probably 310-320hp.
the mcx 310 kit runs 19-21lbs boost with the 19t so in theory you should be making a bit more with the bigger turbo,but you are in that range.header design turbo configuration , intercooler efficiency & fuel set up can change things allot.
26 / 14.7 * 130 + 130 = 359,9HP.
21 / 14,7 * 130 + 130 = 315,7HP.
Seem as a pretty efficient system, and that my guess was pretty spot-on. :)
Remember, an dyno is just a tool, so i never compare one dyno session done @ one dyno against an dyno session done @ another dyno.
