T
tjc
so in research it appears that the MCX 240 kit uses the stock pump with extra injectors. That being said is it possible to increase the injector size on the stock pump and get more than 6 pounds of boost on the stock fuel pump?
Of course you would need to pull fuel down low but could someone use the pump for say 10-12 pounds boost with properly sized injectors? It almost seems like the issues at this boost level (below 10-12) would be the fuel pressure not so much volume but maybe I am way off?
