Nytro Fuel Controller (Stand alone)
H
hasslbri
I have an 08 Nyto with an Impulse Kit (2871 w/ a race gas shim). It was probably installed in latte 08 early 09. It runs a pure logic controller and a prologger. I am wondering if there is any way to upgrade to a different fuel management system (stand alone) and not have to do quite so much adjusting. I was having troubles getting to to run right (rich off bottom and lean on top) last week. I just want to ride and not push buttons quite so much. If there is a better system, what would it cost?
I also am running EZ - Ryde under it and it handles way harder (nose heavy) than a stocker. I understand it is to keep the front down on steep climbs but there are only a couple steep climbs I actually do. Can I set this skid up for more balance? It rides very nice, just looking for better balance for all around fun.
Brian
Impulse has there new standalone kit that you can get. Also there is the Boost-It kit. Its not standalone but easy to adjust and once its set its pretty much set. Not sure on the cost of the standalone from Impulse but Contact NM on here for the boost it kit.
I also have one I would like to sell. Its installed on the sled now, you can hear it run if you like to know its fully functional.. pm me if you like.
Wow!
I also has one I want to sell. Complete standalone with wiring, all sensors, 3x750cc injectors, fuel regulator and Ecu. And instructions!
