nytro eatting avids ?
heres a few pics of what my nytros doing to my avids any ideas ?
yeah i run them all the time even if the trials ok .i put in new hyfaxs with the track and are still on that same pair and they look great . it seems as if the sholders of the clips are diggin in my drivers for some reason . the whole driver track combo has about 600 km on it all at 17 pounds
Looked at mine last night and with over a 1000kms they look mint.....no marks what so ever. That doesnt look like normal wear to me.
avids
Please give me a p.m. i have a reasonable offer for you. I was just going to order a set.
Thanks
useful anti-ratchet information
I see several things when I look at your pictures. The wear that you see on the left hand finger is normal from the guide clips on the track. Skidoo cuts their drivers out a little here, but even they still have wear in this area. That groove also tells me that you installed your drivers in the middle of the track clip holes. Your track is moving left and right about .25" or .5" total. I suggest that you install drivers so that the anti-ratchet point just misses the inside of the track clip holes on each side. Your stock drivers rode in between the two inner rows of rubber nubbins for track alignment and you are no longer using them. Your track might be rubbing on your tunnel. Notice that the anti-ratchet points(the important parts) don't have a mark on them. Robbie Holman Avid Products
thanks for the info , next time ill move my drivers over a bit then . my track isnt rubbing any place in the tunnel though and the groves have gotten a bit worse but now with 1200 km on them im not really worried any more :D
