Nytro CR tunnel and stock exchanger removal
What is the vertic on removing the stock heat exchangers on a turbo nytro when installing a CR tunnel. Can they both be removed, should I keep them both or is just one needed. I don't want any cooling issues.
Thanks
I will know once the snow flies, I removed front heat exchanger and radiator, so I hope it works, I left the under tunnel with the crracing U cooler.
Remove the stock Rad and heat exchanger, the CR tunnel with cooler extrusions and rear u cooler is plenty. Never had a heat light on, even flying down icey trails with no scratchers. Sliders didnt like it tho LOL.
You left the bulkhead cooler in though, right?
