T
thewayout
Working on my Nytro mod with a VE tunnel with 4 pass cooler. Front cooler & rad are gone. Plumbing the thermostat open outlet to running boards / 4 pass cooler & back to water pump inlet. Plumbing the bypass into coolant tank & tee into water pump inlet with line from running board. What is the nicest compact tank to use with 1" or .875" in & out hose fitting. Also would perfer a tank that has some kind of mounting tabs. The mounting is what polaris edge tanks are missing.
Thanks for your suggestions.
