Nytro Clutching
kinneyt
I know that this has been talked about before, but i have spent to much time trying to find what people are using for clutching on a stock Nytro for the bighorns.
Please chime in with what works for that location.
i would like to know some stock clutching to that has bin working i see some are using cat yellow spring how are they making out with it.
you need to regear that sled back to high alt. which is 20/40 and a 68 chain. also remove all the rivets from the weights. and change the primary spring back to the g-w-g. this is the set up for 8,000 to 10,000 and what i ride the snowies with. 6,000 to 8,500 yamaha recommends 20/40 gearing same primary as above and steel 13.3 rivets in the outer hole.
the sled is set up as follows
22/40 gearing 70l chain
l-br-l primary spring
cat yellow secondary
if you need more help call me
Thanks Mike, but I no longer have your number.
