nytro clutching help please
J
jehay
trying to clutch the t-nytro i put a line on both clutches with a marker and took it for a boot. The secondary clutch the line is gone but the premary clutch there is a 1/2 inch line left at the top. So do i need to take some weight away on the tips of the weight or add some? thanks james
ok thanks, one more question i have the powderlites turbo kit so it has daves clutch setup the secondary spring is purple i don't know want kind it is. Trying to figure out what holes to put it in to. I have it in hole 0 on the shockwave and hole 3 on the clutch is that the wright hole to put it in to. What affect does it have if you try different holes?
Sound's like you have Erlandson purple cat spring
I'm using 0 and 1
i think you are write i know its a cat spring and it is purple. You are using 0 and 1 i am using 0 and 3 so want is the differents is 0 and 3 more spring pressure?
Spring
I think the spring Dave sends out with the shockwave is black. Can't remember what the setting is but I know he found a position he liked way better than early settings. Drop him a line and you'll get all the info you need.
Mine clutches out fully on both pr. and sec.
EPI springs
Not to Hi-Jack your thread, but can someone explain the amount of wrap on EPI springs. 0/1, 3/3 everyone has something different. What are the different combinations from softest to stiffest?
thanks guys for your ideas of the fix for my problem but i have got it spot on now:D The clutchs are running all the way to the top and bottom. I screwed around with weight ontill i was blue in the face. and it payed off the sled rips in the end i am using 74 gram weights it pulls 9100 out of the hole then it slowly drops to 8900 and holds it there! with 17 pounds boost:D a/f is 12.0-12.5 so all is good
