Nytro broken secondary
H
Hangtime
New member
Been chasing this clutch noise... i feel like a dumb a... secondary spring was to weak, big belt slippage.
Need a new secondary , anyone have one ?
Did notice the inner sheave part number is the same as alot of yamaha's
inner 8bu-1760-20-00
Outer 8G1 17660-00-00
which sleds take the same unit?
Note to self : if you go from 153 track to 162 x 2.5 make sure to change secondary spring !
Thanks Hangtime
what are you going to change it to and what difference would it make. I am running a artic cat yellow set as loose as I can get only went with this one is to get some back shift the stock spring always hung up deap in the clutch
