Nytro belt ride height on secondary??
WingNutRacing
Sorry, this is my first Yammi and was wondering what exactly I should do to get the belt riding correctly. It sits down in the sec a little too far. I know I need to adjusted the small bolts on the back of the sec, but how... I looked it up in the manual, but was looking for some of your opinions... Do I need to add some special sized washers?????
Thanks
Take the clutch off...look on the back....there are 3 little bolts....there are washers upnder there...I think if you remove them it will raise the belt. If you take the entire clutch apart you can see how the whole set up works....then you will know.
To raise the belt in the secondary you install shims behind the three small bolts on the back side of secondary.Yamaha makes two different size shims.
Autopro
