Good battery power? Starter works? Can you hear the fuel pump when you turn on the key?
That happened to my Nytro one year after sitting for the summer. The injectors were gummed up from the ethanol in the fuel. You can try to pull them and see if they are clogged. If they aren't gummed up you can check the fuse box and see if one is blown. You can bench test them pretty easily to see if they are working, there are tons of youtube videos on how to test injectors.
I'd start with the fuse box if you haven't checked it already. Hopefully it is a simple solution.
